Kyocera FS 8100DN error 7913:0025097
  • Nelo
    • Aug 2025
    Kyocera FS 8100 DN having the error 7913:0025097, replaced every consumables and did basic reset "switch off and then on" error still remain. Kindly need assistance on this error, what does it relate to?
    • 23010
    Re: Kyocera FS 8100DN error 7913:0025097
    Two questions:
    1) Why are you replacing all the consumables at 25,097 prints?
    2) Have you looked up the 7913 error code in the service manual?
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
      Paul@justmanuals.com
      • Nelo
        Two questions:
        I dont have a service manual and suspecting faulty consumables I replaced them to see if the error would go off. Im like confused and not sure witch section the error might relate to.
          • 23010
          You wouldn't be confused if you read the service manual.
          I don't read manuals to people who are perfectly able to read, or are too lazy to read.
          You probably spent $600 on unnecessary parts to save the cost of a $12.77 manual.
          Please read the manual. Please try something. Then please ask for help only then. =^..^=
          • JR2ALTA
            • Feb 2010
            • 2033
            I wont pile on, other than to say it's a FS-C8100dn.
            Your code is for the Magenta Developer unit.
            Replace M dev. unit or Engine Board.
            • Forest K
              • May 2019
              • 6
              Didn't mean to like OR thank you for the post!! If YOU had looked at the error, you would have seen its for magenta dv unit.
              • CWP
                • Jun 2013
                • 168
                You are seriously going to blast someone for a (valid) reply to a post almost 11 years ago? That's brilliant!
                • ntbann
                  • Jan 2012
                  • 631
                  And Black Cat no less! He is probably the most knowledgeable person on here! You should be black listed. Everyone remember Forest K. No help for him!
