KM-5050 Network port won't light up
  • alt
    • May 2025
    Hi all,
    As said above network port on the photocopier won't light up. Not a thing, nada.
    I've tried connecting it to the dsl router, hubs, switches. I have also tried different CAT5 cables, still nothing.
    I am presuming it's a straight-through cable you use, and not a cross-over?
    I am just asking here to check if there's any root settings etc. that may need to be changed to activate the LAN port?
    Thanks in advance for any help you can provide
  • JR2ALTA
    • Feb 2010
    • 2028
    tcp/ip can be turned off.whether that disables the link light i'm not sure
    • GESPAGE
      • May 2011
      • 40
      Re: KM-5050 Network port won't light up
      Originally posted by alt
      Hi all,
      U906
      Resetting partial operation control
      Description
      Resets the service call code for partial operation control.
      Purpose
      To be reset after partial operation is performed due to problems in the casettes or other sections, and the
      related parts are serviced.
      Method
      1. Press the start key.
      2. Press [EXECUTE] on the touch panel.
      3. Press the start key to reset partial operation control.
      The maintenance mode is exited, and the machine returns to the same status as when the main power
      switch is turned on.
      • daveh12
        • Jul 2012
        • 157
        It could be the network card itself that's faulty.
          • 22930
          Are you sure that the network connection is live? the first thing I do is connect my laptop to the existing network cable and see if DHCP assigns an address. If yes, I'll start a continuous ping and watch it for a while.
          In five years I've replaced exactly one controller board for dead TCP/IP port. That's pretty rare. =^..^=
