kyocera KM-4530
  • TEC DOG
    • Sep 2011
    • 113
    kyocera KM-4530
    Hi
    I have kyocera KM-4530 with fixing issue.Fuser rotates unevenly with clicking and green handle for rollers jumpsbut when i pull out unit and turn by hand it's seems OK.I take apart whole unit,check gears and belts etc....nothing. Can be a drive clutch ?
  • madas
    • Aug 2008
    • 313
    Re: kyocera KM-4530
    Hi, have you checked the drive gear on the machine its self to see if theres any damage?
    what condition are the bushings for press roller and heat roller in?
    can you see the fuser if you trick the door switch to look for anything obvious, it might just occur at speed.
    madas
    • JustManuals
      • Jan 2006
      • 9838
      Re: kyocera KM-4530
      Paul@justmanuals.com
      • TEC DOG
        • Sep 2011
        • 113
        Re: kyocera KM-4530
        Thanks for response Midas.I found broken gear on fixing drive 100 miles deep. Thanks again.
        Thanks to Paul also.
        • unitechro
          supervisor
          • Feb 2012
          • 9
          Re: kyocera KM-4530
          hi ,
          i 'm loocking for kyocera manuals and fimware.
          i can exchanged them with ricoh(all),canon,toshiba.
          merci
