FS-9530 DN error f226
  • Darthgeoff
    [Error Code] FS-9530 DN error f226
    Hi there
    I have a fs-9530dn coming up with the error f226 i have replaced main-board , engine-board and also the dimm on the main-board the info in the manual is video output error ,Replace main-board.firmware upgrade has always been done when each board has been replaced ,printer will come up to ready status but when you print a status page a blank page is printed then f226 error code appears
    • 23008
    Re: FS-9530 DN error f226
    The reference I have points to the DDR2 memory. Have you changed the memory chips?
    • Tonerkiller
      • Oct 2012
      • 668
      I have a 9530 that is intermittently giving a 226 code. Does anyone have a solution?
      • Tonerkiller
        • Oct 2012
        • 668
        It pulled the code again today. Very intermittent. Any more info? I was able to reset by turning the machine off and on.
