FS-1128MFP
  • Ingersoll
    • Nov 2008
    • 74
    [CQ] FS-1128MFP
    I have a FS-1128MFP,
    Prints are fine, copies & faxes thru the ADF (and off platen glass) have a gray background w/ a 3mm blank /(white) border around the entire page. Any ideas what causes this? It has to be from the scanner assy [PARTS ISU ASSY] but is it possible to fix w/o replacing scanner unit? On other machines I have seen a background level adjust which can resolve this same type of issue, but not on this model.
  • JustManuals
    • Jan 2006
    • 9838
    Re: FS-1128MFP
    Paul@justmanuals.com
    • cwilli07
      Re: FS-1128MFP
      I have had this same issue before and the fix for ours was on the ISU there is a small board under the mirrors that went bad and had to be replaced, although we had the part on hand due to a 1128 the got hit by lightning. Looking at the parts man right now and there is not a part number for it, you may have to order the ISU... Or call Kyocera's parts department..
      • Ingersoll
        • Nov 2008
        • 74
        Re: FS-1128MFP
        Thanks for the info, I figured it was something like that.
        I did not need a manual. I wonder how much he makes advertising for manuals?
        Oh I see, $12.97 for something he probably got from Kyocera web site for free. NICE
        manuals4you
        Re: FS-1128MFP
        • kkendric
          • 301
          Re: FS-1128MFP
          TB CS-255/305 #2 MEASURE TO ADDRESS A BLACK IMAGE OR A C3200 ERROR CODE
          I II have seen this cause grey copies as well. there is a transistor on the main board in the power supply section for the CCD that is defective causing this . Bulletin was issued 11/15/11.
          • kkendric
            • 301
            Re: FS-1128MFP
            Sorry, wrong machine had the 255/305 on my mind.
            • Ingersoll
              • Nov 2008
              • 74
              Re: FS-1128MFP
              Part number is 302H993040 PARTS ISU ASSY
              • Geo
                • 662
                Re: FS-1128MFP
                [QUOTE=Ingersoll;335528]Thanks for the info, I figured it was something like that.
                Ingersoll...You must be careful when commenting or questioning
                manuals4you" or he will red flag your reputation rating.
                Cheers.
                • Ingersoll
                  • Nov 2008
                  • 74
                  Re: FS-1128MFP
                  [QUOTE=Geo;450636]
                  Cheers.
                  I have had conversations with Paul, he's a good sort. Just doing his job. I wish I had thought of it first B-)
                  • Geo
                    • 662
                    Re: FS-1128MFP
                    [QUOTE=Ingersoll;450859]
                    He may be a good sort to those that agree and condone his "activities" and the way he helps people.. Not so good to those that debate or disagree with his sometimes mean spirited responses and actions.
                    Cheers
                    • darry1322
                      • Oct 2010
                      • 817
                      Re: FS-1128MFP
                      [QUOTE=Geo;450896]
                      Cheers
                      Paul is no longer with us. He passed away recently.
                      http://www.copytechnet.com/forums/ra...ife-sucks.html
                      • JBWiss
                        • Dec 2014
                        • 10
                        Re: FS-1128MFP
                        check connector on lamp and clean the mirrors and lamp before getting new.
                        • Ingersoll
                          • Nov 2008
                          • 74
                          Re: FS-1128MFP
                          Thanks, I did those things before my posting. SOP (Standard Operating Procedures).
                          I have been doing copiers 15 years, HP Printers/MFPs 20 years.
                          • JBWiss
                            • Dec 2014
                            • 10
                            Re: FS-1128MFP
                            Sorry, auto-pilot.
                            • Ingersoll
                              • Nov 2008
                              • 74
                              Re: FS-1128MFP
                              Sorry, auto-pilot.
                              No Problem, I usually check copytechnet for folks that have had similiar issues, and google helps sometimes.
