TA 3001
  • Max
    • Oct 2011
    • 569
    TA 3001
    I just had a TA 3001 come back from a customer and every time i try to access system menu i get cannot connect to authentication server. Usually i d get the wrong password message but this is different. i called the customer they did not know anything about it and i never set up any server authentication. I formatted hdd and reset the whole thing to factory setting to no avail. I had a look through all the menus and i cant see any server authentication options or how to turn it off. Can any one help please.
  • xeroid
    Document Technologies Pro
    • 148
    Re: TA 3001
    Have you tried U21?
    • Max
      • Oct 2011
      • 569
      Re: TA 3001
      Yes i tried it makes no difference. Still asking for a connection to authentication server.
      • xeroid
        • 148
        Re: TA 3001
        Perhaps you have the Access Lock Hypas app installed. You would have to remove that. Also If you are set to require authentication this may be your problem but a u21 should have reset that.
