Paper tray out of order KM5035
  • draph
    • 132
    I've read the posts about lift motors and engine boards. My problem is it gives this message for all 3 trays. All went out at the same time. Bypass still works. Question is this; if engine board goes will it knock out all of the tray controls on the engine board or just one at a time? I've done the reset with no result.
    • 23010
    Re: Paper tray out of order KM5035
    Unusual, sure. Not impossible.
    What I would do is unplug all the lift motors, then meter the connector to see if your getting 24vdc. If I were a gambling man I'd bet that you have lost the 24vdc, and the ground switching is still working. Check each lead to frame ground.
    Not that it's a critical difference, because it still leads you back to the engine PWB. I suppose you could check the 24vdc inputs to the engine PWB, to make sure that the 24v is being supplied by the PS. Just to be safe, I think I'd also change the lift motors in the same operation. It would be a shame to blow another engine PWB. =^..^=
