All
I've just setup a km-2550 printer and have both network print and copy functions working fine.
Also smtp is setup as i am receiving status updates from the printer.
I just cant get the scan to pc or email working
scan to pc: I've made sure that the folder used has access (security set to everyone and on root of server) firewall is not on and setting are correct. Question: is all you have to do on the printer is set 1 item on the destination list with a name and the server ip address?
Scan to email: I want to use the ldap converter, it has scanned our domain and received the address, but theses aren't uploading to the scanner! I cant see where the setting are to point to the "ldap converter" server are on the scanner, All i have under ""send e-mail" settings" is "email basic settings" and "destination list". no option to point to ldap converter server at all.
All user and setup guides say that there is a option on the scanner to do this but not on our one!
Also if anyone has the latest firmware for this printer/scanner, i'd really appreciate it!
regards
Wex!
regards
Wex!
