My Kyocera TASKalfa 2420w shows my printer offline..!!
  • sulabh
    • Oct 2012
    • 15
    i have Kyocera TASKalfa 2420w, when i started it today morning the printer displayed that the printer is offline and the paper roll not found even though it was there.
    i tried restarting it many times and tried inserting the paper roll many times but did not worked. And another thing when i insert the paper roll it should pop up with what type and size of paper is.. but that is also not popping up when i shut the door.
    Please help. Urgent..!!!
  • JustManuals
    • Jan 2006
    • 9838
    Re: My Kyocera TASKalfa 2420w shows my printer offline..!!
    Paul@justmanuals.com
    • psraji
      • 6
      Hi,
      To check with your supplier and update the latest IPS version 7.4; This will helps to resolved the entire problems.
      • rashid120
        • Jun 2010
        • 76
        update the plotter with patch file.
        Thanks.
        • Donnie
          • Aug 2011
          • 79
          We have had to dis-able snmp ( on ports tab) on some other machine models for a similar problem. Shows offline, you may get it to work for a few minutes then shows off line again.
          • swansandre@gmail.com
            • Jun 2022
            • 1
            I have same problem was this ever solved jobs in que is asking for paper paper is installed any idees. Not printer driver related cleaned all sensors and also in simulation all sensors are working and can make a test print
              • 16395
              This thread was started in 2013. I don't think the OP is gonna respond. Start a new thread.
                • 30248
                MS broke snmp years ago always disable snmp on every install
                It sends the error to the driver but once the error is resolved it never sends the ok back to the print driver.
