Have a problem with cassette 1 on a km2560, will be feeding paper as normal, and during a job it just stops and says add paper in cassette even though it has plenty of paper. Switched cassettes and pick-up assemblies and problem stays with cassette one. Connectors all fine and seated correctly and has latest firmware. If you open and close cassette when it stops it will carry on but says add paper again randomly, could be after 3 - 100 copies. Doesn't follow a pattern. Any help appreciated.
KM2560 - cassette
Re: KM2560 - cassette
Also check the lift drive coupler. The spring loaded coupler will bind on the plastic splined shaft, or paper can get pressed into the coupler.
It's much more common to have the lift motor short out, taking the motor driver circuit on the main PWB with. In this situation it won't reset though. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
Have a problem with cassette 1 on a km2560, will be feeding paper as normal, and during a job it just stops and says add paper in cassette even though it has plenty of paper. Switched cassettes and pick-up assemblies and problem stays with cassette one. Connectors all fine and seated correctly and has latest firmware. If you open and close cassette when it stops it will carry on but says add paper again randomly, could be after 3 - 100 copies. Doesn't follow a pattern. Any help appreciated.Comment
