FS3140MFP - 0840 Error codes on separate machines
  • DWise
    • 895
    [Error Code] FS3140MFP - 0840 Error codes on separate machines
    We have a customer that has had two separate FS3140MFP's display the same error (0840) in this particular office.
    With the first printer, they replaced the batteries twice and the Main PWB. After not being able to clear the error, they replaced the printer with another one that was working well (in another office, same building). Replacement printer shows same error. They can power-cycle the printer and the error will clear.
    The tech is going to upgrade firmware and check the power (in room), but I just wanted to check and see if any one else has had a similar issue?
    Do for one what you wished you could do for everyone. - Andy Stanley
  • jewen25
    • Mar 2009
    • 197
    Re: FS3140MFP - 0840 Error codes on separate machines
    Try apply sim to factory setting,i think 020 sim
    ERROR HELP ME AND HELP YOU
