Taskalfa 400CI Jam first copy every morning
  • FINGERS123
    • Nov 2012
    • 33
    I have a customer that states that their machine jams first copy every morning and then after that it works fine. They have the 3000 sheet drawer but can not tell me what drawer it jams out of more. I asked them to test each drawer on separate days and let me know what happens. I checked the jam counts and found 212 jam 51, already replaced the exit and fuser units. Any ideas.
  • Kidaver
    Ghoulscout
    • Apr 2011
    • 912
    Re: Taskalfa 400CI Jam first copy every morning
    Does the machine have a job separator? There is a tech bulletin for the rollers in these. This might be something to check into. Also look for toner build up above the fuser unit. You said the exit unit was replaced so it probably has the new style one, so it probably has the metal guard with to help from keeping the gear getting wallowed out.
    "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
    • FINGERS123
      • Nov 2012
      • 33
      It has a job separtor on it and already checked the roller.
      • Tonerkiller
        • Oct 2012
        • 669
        I have resolved this issue by replacing the tires in the paper drawers.
          • 23010
          On two machines after replacing exit assy, fuser, then job separator sensors and rollers, I replaced the job separator assembly to resolve the problem. Watch through the paper through the slot as it passes into the finisher. If by some miracle you actually see it happen, you'll see the paper slow down significantly before jamming. =^..^=
          • brecht2
            • Feb 2012
            • 71
            I had some clients with the same issue!
            First copie jammed.
            It happens always in cold seasons (winter etc...)
            I think it's humidity on the upper page in de drawer...
            • Mike L
              • Jun 2012
              • 11
              I have the problem with a TA-250ci
              Fuser Unit + Exit unit changed without success
              Fuser Casette install U325 on + jack fuser install without success
              the first Paper is jam or curly
              Firmware is 13 Counter is 10000
              • JVergin
                Service Tech / IT Rep
                • 216
                http://www.copytechnet.com/forums/ky...y-morning.html
                • Zackuth
                  • Aug 2009
                  • 448
                  There is a solenoid that operates the entry guide--303JY44060 Solenoid Divergence--that might be bad. We had a problem like that and the solenoid was the answer.
                  If at first you don't succeed, redefine success
                  • brecht2
                    • Feb 2012
                    • 71
                    How it could be this solenoid if the paper jammed in the exit (j51) and not between the machine and finisher (entry DF-760)?
                    I saw in the manual there are 2 of this solenoids with part
                    nr 303JY44060. You changed both?
                    grts
