kYOCERA 4050 , SC 7410
  • pinspin
    • Oct 2011
    • 156
    [Error Code] kYOCERA 4050 , SC 7410
    Hello. I installed the repair kit MK-715 in Kyocera 4050. After switching on the copier shows code SC 7410. It turned out that the machine had drum unit DK - 716 installed, and the repair kit had a drum unit DK - 715 . Can I use the drum unit DK - 715 instead of the drum unit DK - 716? If so, what do i need to do? thanks
  • kkendric
    • 301
    Re: kYOCERA 4050 , SC 7410
    DK715 used in KM-3050 only
    DK716 used in KM4050 and K5050 only
      • 23009
      Correct. If I remember correctly the drum itself is the same, the difference is with the chip and the drum cleaning lamps. If you insert the new drum into the old unit it will work, but you'll still be stuck with the maintenance indication. =^..^=
      • pinspin
        • Oct 2011
        • 156
        thanks
        • pinspin
          • Oct 2011
          • 156
          thanks , I will try to change
          • cysec
            • Jun 2008
            • 21
            Another option I have had success with us to swap the connector board at the back of the drum unit. Though I wouldn't advise doing this if you are trying to put a 3050 unit into a 4050 or 5050 as the CQ will likely decline rather quickly.
