Falcon ll
  • Franky Tan
    • Jul 2025
    Falcon ll
    Thank to All for c6020 error code solution.I have another problem to face which is black dots appear on copy ,my superior said is caused by drum unit but lifespan is due on 500k. Those blackdots on copy by drum unit about 300k, so i think there is away to settle it rather than change drum unit. Your solution is greatly appreacited. Thankyou (caused by sparkling)
  • Mark B
    • Jul 2006
    • 153
    It needs a drum unit. The grid was arching to the drum.
    • 10871087
      • Jan 2005
      • 1062
      You probably need a drum, do the spots have the same pattern on all output including status pages?
      • texchar555
        Senior Production Tech
        • Mar 2007
        • 142
        Leaw, The black dots come from your main charge unit. The customer using the cleaning pad is not letting the grid dry up which causing the drum and the mc unit arc. Yes I agree with the others, change the drum unit.
        • Franky Tan
          falconll
          Today i change a used drum unit ,black dot became smaller but i didn't tried status page may be i let you all know later , one thing i about forgot we used to swap used drum unit,developer unit and fixing unit to cut cost.The black dots have variable pattern ,its confirm caused by arc .thanks for help.
          • Franky Tan
            Hello ! can you more specify on cleaning pad ,which is located at where ? thankyou.
            • JSC
              Gimp
              • Dec 2006
              • 618
              Comes with the toner, I tell my cutomers not to bother & leave the cleaners in the cab % let the engineers do it.
              The gene pool could use a little chlorine.
              • just a tech
                • Jan 2007
                • 332
                in the foil pack that comes with the toner in the box. also has directions with it. intended for customer to use for cleaning main charge grid at time of toner change. afterward, customer needs to let main charge "hang" out of front of copier to airdry. if it doesn't airdry and is still wet, it can arc and cause really small pits to drum.. also, if it's not clean, i believe it's just as bad due to main charge grid being dirty and arcing anyways or causing other copy quality problems as well..
                • Franky Tan
                  Thanks to all.
