Hi guys !!!! Is it possibile scan with this multifunction and Mac OS X 10.8.2 ???? Scanner file utility doesn't function.... :-(
scan to mac scan taskalfa 221
Re: scan to mac scan taskalfa 221
You are right on that one, I have thought of a different machine as I always have to translate it in to terms of UTAX or Olivetti...
PUT WIN 8 on the Macdual boot
I think they should make an app for that!!
do you have set to scan system F board on task 221.
see this guide
http://www.utax.de/C125712200447418/vwLookupDownloads/IH_ScanSystem%28F%29Setup.pdf/$FILE/IH_ScanSystem%28F%29Setup.pdfBlack is Kyocera , Color is Gestetner.Comment
ho provato ma non riesco.
qualcuno sa dirmi in italiano come si fa .... ricordo che ho un mac
grazieComment
if you cant run smb or scan to mail on Mac . you must try scan to ftp .
before you have download free FTP software on Net , and install on mac ,
https://www.macupdate.com/app/mac/44254/ftp-server or other Free FTP server program for Mac.
and create empty folder and share over FTP server. you have set anonymous login. ( allow full control,write permission).
after you have set FTP server IP and path on Scan system F.
regards.Black is Kyocera , Color is Gestetner.Comment
if you cant run smb or scan to mail on Mac . you must try scan to ftp .before you have download free FTP software on Net , and install on mac , https://www.macupdate.com/app/mac/44254/ftp-server or other Free FTP server program for Mac.and create empty folder and share over FTP server. you have set anonymous login. ( allow full control,write permission).after you have set FTP server IP and path on Scan system F.regards.Comment
