Hai...
we are facing a copy quality issue in Taskalfa 250,300.400and 500Ci machines...frequently we are changing drum units for pin holes problem...not even crossing 100k prints.... new Fw updated....the cassette heaters turned on...did the adjustments which is attached with the new drum unit kit ...
we noticed some points...this problem arrives, where we updated the new firmware ie: with the Pantone symbol.we have some machine in the field with the old firmware... its working fine, up-to today with out any pin holes issues....when we upload the new firmware ,after replacing developer .drum or transfer belt....then the pin hole problem starts....
is there any solution for this issue...any problem with the new firmwares....
we are working at middle east countries... here the summer temperature will be nearly 40-50 Celsius and the humidity level also will be high...is there any necessary to turn on the cassette heater?...any other settings to be adjusted?...
