kyocera taskalfa 250ci. copy black
  • tullio
    • Feb 2012
    • 268
    in print and 'ok. in copy and scanner, the image and 'black.2013-03-11 16.44.19.jpg2013-03-11 16.44.36.jpg in printer ok. the light comes on.
    urgent
  • koop
    Re: kyocera taskalfa 250ci. copy black
    Hi, i have a same problem!! Did you fix it and how? Anybody? Please help
    • kibbs
      • Apr 2013
      • 94
      try to clean the charger the roller until the it become black color then refresh the drum and developer.. then also print is not okay..! check the life count of drum and developer changed it...
        • 23009
        Wow, that's an old thread.
        @koop: if you are having the exact same symptoms as tulio, it isn't a print engine problem, it's an image processing problem. A short list of possible causes includes:
        CCD
        scanner PWB
        main PWB
        Is you're machine set up to scan? What result? =^..^=
        • koop
          Hello all,
          Blackcat you were right, it is the ISC PWB gone bad tnx for the help!!!
          Have a nice day
