Km 3050/4050/5050
  • Mess
    Copier Gawd
    • 81
    Km 3050/4050/5050
    the machine says add paper in tray 1 ,tray 1 is full and the sensors are working. there is a job in memory that will not print. Machine will not copy or print in this state. I am able to fax OUT.and receive but it will not print out anything. Any suggestions?
    • 30300
    fax
    we seen this ,pull out all paper trays machine will tell you what paper size it needs
    than check , machine is looking for fax paper 11 by 17 or a size thats not in machine. configure fax to print bypass and set size
    once its clear turn on fax auto reduction for paper sizes
      • 23009
      Also check to see if there is a media type specification. If its seeking 8 1/2 x 11 letterhead, and you have loaded 8 1/2 x 11 plain it may not accept the substitution. Also enable auto tray switching. For printing it's defaulted to off (R1,0. Send this command from KM-Net Viewer:
      !R! FRPO R1,99; EXIT;
      • B0265
        • Jan 2007
        • 718
        Also check that size setting for the cassette is "auto", if I remember correctly the machine will not print out Fax from a cassette that have a fixed size setting.
        • kyoceradude
          The Great Gazoo
          • Aug 2006
          • 442
          Yes, Set fax default paper tray to bypass. You need to do this in Command Center. Also 205A firmware takes care of problem.
          My mission here on Earth is to help all you Dum-Dums!
          • Mess
            Copier Gawd
            • 81
            thank you all for your help. the above instructions fixed my problem
            • copygirl
              • 75
              You may have a size conflict on the print side. Computer is sending a certain size that you don't have in machine. Check all your defaults on machine and on driver. You can also go into the page setup in whatever program you're printing from to see what size the job was set up with. Good luck.
              Ginger
