Taskalfa 300i Left Door Contact Switch
  • gocopy
    • Dec 2012
    • 18
    Hi forum, I have run across 2 TaskAlfa 300i with jamming problems due to left door not pushing closed door switch far enough. Is there a work around instead of tape on door contact? Thanks.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Taskalfa 300i Left Door Contact Switch
    Paul@justmanuals.com
      • 23010
      If your endusers are slamming the door it will get bent. You can reform it once or twice, but you really need to educate your endusers to close first the inner duplex section, then second the outer door, and definitely no need to slam. =^..^=
      • gocopy
        • Dec 2012
        • 18
        Thanks BlackCat, will try to reform them and tell endusers that great tip about "no need to slam"
        • leroyal
          Expert on The Obsolete
          • Sep 2007
          • 156
          Look for cracks in the white latches
          I know what I know better than anyone else knows what I know.
          • gocopy
            • Dec 2012
            • 18
            Cool Leroyal, looks like those white latches may be playing a part in the left door not making a good contact! This forum is great! Reform left door contact switch and replace white latches might just do. Thanks
