CS4050 & KM4050 are the boards the same? C2000 code
  • Itsthepaper
    Supervisor
    • Dec 2007
    • 91
    Hello,
    I have a CS4050 popping a C2000 stapler motor code, machine has a DF-720. Manual says it's the motor or the engine PWB. Well I removed the DF_720 and still code pops, I'm shooting for the Engine PWB. I have KM4050 in the boneyard pile are the PWB's the same?
    Love the Job Love the Work.
    • 23009
    Re: CS4050 & KM4050 are the boards the same? C2000 code
    Yes, just be sure to swap any removable EEPROMs and Memory chips to the replacement board. =^..^=
    • Kidaver
      Ghoulscout
      • Apr 2011
      • 912
      One thing to watch for on this as I grabbed a 4050 board off a 5050 we had come back into the shop. At some point they changed the drive system in these machines and added a clutch to run the developer separately. The old board will not have a connector for this new clutch but the new one will. Imagine how irritated I was getting this other board into a machine and discovering there isn't a connector for this clutch. Came back to the shop and found the bulletin on it.
      "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
      • kkendric
        • 301
        Has nothing to do with a stapler motor,2000 codes usually deal with the main drive system. Main motor , gears, engine board etc.
        C2000:
        Drive motor problem
        Stable OFF is detected for 1 s continuouslyafter drive motor stability.The drive motor is not stabilized in 6 s
        since the motor is activated.
        • Techman1000
          • Dec 2010
          • 44
          Check the drum unit, We have had the cleaning unit inside the drum unit locked up on Taskals 520i, which is almost the same drum unit.
          When this happens it puts such a atrain on the main motor that the copier will throw a 2000 error code!
            • 23009
            Good catch Kidaver. I too have come across this. =^..^=
            • Itsthepaper
              Supervisor
              • Dec 2007
              • 91
              C2000:
              Drive motor problem
              That's what I'm going to try next, I'm not to familiar with KM boxes and when I saw Stapler on the manual I automatically took that route with boards and stapler assembly troubleshooting. I suspected maybe something esle going on and you just confirmed it for me.
              Thanks I'll follow up later with what I found.
              • Itsthepaper
                Supervisor
                • Dec 2007
                • 91
                Thanks Techman1000, Drum unit bound up. Swapped drum all is good.
                Thanks you all for the help!!!
