Taskalpha 250ci Jam every Morning
  • Mike L
    • Jun 2012
    • 11
    [Jamming] Taskalpha 250ci Jam every Morning
    the first Paper is jam or curly
    I have the problem with a TA-250ci
    Fuser Unit + Exit unit changed without success
    Fuser Casette install U325 on + jack fuser install without success
    Exit Speed+ Fuser Speed + and - without success
    Firmware is 13 Counter is 10000
    my english is bad i come from Germany
  • JVergin
    Service Tech / IT Rep
    • 216
    Re: Taskalpha 250ci Jam every Morning
    J51?
    Go to kdaconnect.com and sign in under your username and password.
    go to technical resources -> Knowledge base -> QA Search
    Search for "B319"
    There is a set of rollers on a shaft in the Job Separator unit that can expand and run idle when the machine heats up. It starts as only the first copy of the day...and then progresses. gorilla gluing the rollers to the shaft is my temporary fix until I can get the part delivered. The bulletin should have all the info you need on part numbers and what exactly needs to be replaced.
    • Mike L
      • Jun 2012
      • 11
      The TA-250ci has`t a JS 720
      I musttomorow print the event log for the jam code.
      thank you for the answer
      • HenryT2
        • 962
        Where we are in the USA , curling paper is mostly caused by moisture in the paper.
        What environment is this unit in ... warehouse ... office ... under an air vent ...
        Do they turn it off at night ?
        "The Serenity Prayer" . . .
        God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
        • Mike L
          • Jun 2012
          • 11
          the TA-250ci stand in a little post office the hhumidity is high thereforewe have an heater in all paper trade
            • 23009
            If your getting J51 and J81 jams you might try replacing the JS-720 job separator. =^..^=
