ta 520i error code c0640
  • tlf
    • 39
    Have a head banger here. this code will not reset with the sim codes formatting goes into on off right away. 906 just hangs and never tells you to turn off. scan disk goes into on off also tech support said hd s or sata cables. I had spare sata cables no change had 1 500 gig sata hd that was ready and formatted. tried it in both hd locations and did the regular sim settings still the same . Both orginal hd can be formatted on the computer and tested and work fine running out of ideas I have been told to consider the dims in the control panel or pcb control panel and possibly the main pwb. I did load firmware in the machine all passed except the cpu firmware failed ( maybe the error the machine is locked in is stopping it.)
    • 23010
    Re: ta 520i error code c0640
    If you haven't changed the OEM HDD yet, I'd do that first.
    It sounds as thought you'd like to do everything ... except what the C0640 suggests. You're making this much more difficult than it needs to be. =^..^=
    • Eric1968
      • 2458
      Just replace the HDD. Had the same on a Taskalfa 4550ci. If formatting doesn't solve it, just replace it.
      • tlf
        • 39
        Thanks for the info guys I low level formatted the hard drives and tried them in a working machine hard drives were fine. Plugged the hard drives in the on the machine with the error code and it still popped the code machine would never allow a 906 reset or allow you to update cpu firmware.Replaced main pwb and resolved the issue just glad i was able to still warranty the board just made the 3 year warranty.
          • 23010
          Thanks for posting back. I'll keep that in mind. =^..^=
          • habik
            • 2013
            In case you need to replace the Main PWB there is option to get repaired one for part exchange at much lower cost! Just to keep that in mind. Better than buying brand New. The difference is almost 50% of New!
            Firmwares HERE
