Error code 4200 Copystar 4050
  • mach1don
    • Oct 2011
    • 16
    [Error Code] Error code 4200 Copystar 4050
    We have a copystar 4050 with a 4200 code that just won't go away. We replaced with new: drum unit, charge, laser unit, wire harness to laser, engine pwb, and tried the ferrile magnet idea and current firmware. No good results. We also tried removing items from the copier to see if we could pass the problem, such as the high voltage board and transfer roller, still pops up with a code. The laser unit is winding up the motor, so voltage is being supplied, apparently still no beam detect. We did not try the main board- because of expense and high doubts. Does anyone have a solid answer that will point to the exact answer? Would anyone have a board that we could try/purchase? Don
  • Jimbo1
    • Mar 2008
    • 845
    Re: Error code 4200 Copystar 4050
    Replace the switches on the left door.
    "Some days you get the bear, some days the bear gets you."
    Cdr. William Riker
    • DWise
      • 895
      I agree. Replace the Interlock Switches.
      Do for one what you wished you could do for everyone. - Andy Stanley
      • mach1don
        • Oct 2011
        • 16
        Yes, we replaced the left door interlock switches , but still no good.
        • Jimbo1
          • Mar 2008
          • 845
          Ok....check the contacts on the transfer roller assy. They contact into sockets in the machine and these can give you issues like that also.
          Cdr. William Riker
          • mach1don
            • Oct 2011
            • 16
            we actually tried running it with the left side door open, and then tried running it with no high voltage board installed at different times ofcourse. If there's no high voltage, it shouldn't short out.
            • Tonerkiller
              • Oct 2012
              • 668
              How about the front door switches?
              • mach1don
                • Oct 2011
                • 16
                Jumped them, and swapped out the mini switch.
                • mach1don
                  • Oct 2011
                  • 16
                  The power supply does put out the 24 volts at pin5 at yc8 and we have also seen the print head spinning.
                  • JustManuals
                    • Jan 2006
                    • 9838
                    Paul@justmanuals.com
                      • 23002
                      I don't have any unique suggestions, but will try to explain the previous suggestions. It's relatively common on Kyocera machines to display C4200 or other laser codes when any sort of high voltage arcing occurs. It's typical to run the laser's 24vdc through the door interlock switches.
                      I'd have to say that the only thing left is the main PWB. It's too bad you don't have a PWB to test swap in. =^..^=
                      • mach1don
                        • Oct 2011
                        • 16
                        OK, After all this time, we found a solution. We finally got a used main board from a helping dealer, and it initially did not work, so we decided to exchange the new laser unit from Copystar/Kyroceramita with the old one again, and it decided to work!!! So after all this grief, It turns out it was the Main Board. The new laser unit that was shipped to us was defective. Thanx to all who gave us help- much appreciated!!!
