3500I j4711
  • Tonerkiller
    • Oct 2012
    • 668
    3500I j4711
    I have a 3500i with intermittant j-4711. I have not seen it jam, but the customer tells me that the paper comes out above the js-732 some times. any one else seen this.
  • 20gaugeO/U
    • 557
    Re: 3500I j4711
    Check bulletin B438-2LC-0047 with your machine Serial Number. The gates will stick and hang up. Had a rash of them recently and now they are on backorder.
    • Tonerkiller
      • Oct 2012
      • 668
      Re: 3500I j4711
      Did you just warranty the whole exit unit?
      • 20gaugeO/U
        • 557
        Re: 3500I j4711
        It only affected the first 12 machines we ordered. The 2 gates cost around $15. After the first one happened we just ordered more and do them when the customer calls. Once you do one it's easy. Didn't bother with warranty.
        • Tonerkiller
          • Oct 2012
          • 668
          Re: 3500I j4711
          • RobertOB
            • Dec 2018
            • 26
            Re: 3500I j4711
            Sorry to Rez this thread - But we have a 4501i in our shop for repair that is doing the same thing, but as that we are in Canada we can't find the bulletin B438-2LC-0047 that was mentioned. Could someone with access to it attach it or send it to me please?
            • GeneOR95
              • Feb 2018
              • 161
              Re: 3500I j4711
              See if this worked.
              • ntbann
                • Jan 2012
                • 628
                Re: 3500I j4711
                I think if you order an exit unit it will have the retro parts already installed.
                • RobertOB
                  • Dec 2018
                  • 26
                  Re: 3500I j4711
                  Thank you very much. I hope this helps.
