KM2525E scanner issue??
  • dickierock
    • 252
    Hi, anyone seen this before.I have attached images of copies from the scanner of km2525e.I printed a u89 colour band from internal so I know this is a scanner issue. Also the issue is the same when copying from doc feed.I should have done a reduction/enlargement to see if that changed anything but alas.
    Also cleaned under the white reference plate. I can't see anything in the manual to adjust/reset the scanner quality bar the user adjusment.
    Anyone seen anything like this before I start taking this on??
    Cheers.
    • 23009
    Re: KM2525E scanner issue??
    I'm assuming that this is a KM-C2525E.
    I'd start by cleaning the white level reference. Next try changing the shading position, that is, the position that the scanner sits when viewing the white level reference. If there is a scar or discoloration of the white reference, sometimes you can work around it just by changing the shading position.
    As always, do a full calibration after these adjustments. =^..^=
    • dickierock
      • 252
      Hi blackcat,
      yeah i think you may be right.i cleaned the white reference and there was a good amount of dirt/grit stuck under it.I was in a rush so I think it may be possible its not right.I'm going back next week with a good one and will report back.Thanks for you assistance,as always very helpful.
