Stapling issue with printer driver taskalfia 300ci
  • wintsch
    Hi all - new to the board. Having issues with stapling (printing) from a Windows 7 Lenovo laptop. The default windows driver left a lot to be desired with options for stapling. Contacted Kyocera support and they had me install KX Driver ver 6.0.2212. As promised the stapling options are much easier to use BUT there is a conflict on the stapling option so I can't select anything. I changed no settings right from install and I'm given no indication of what the conflict is. I only have two paper tray options (automatic, and top face up). Not sure but it seems like there were more before. This machine is oddly networked so I have to set the IP manually because its on a different subnet. Other then the punch unit, which also seems to have conflicts, the features appear fine and we can print successfully using the driver. I can't find any documentation on this. Any ideas?
    • 23010
    Re: Stapling issue with printer driver taskalfia 300ci
    I suspect you have not configured the driver to the existing accessories. From driver Properties, select the Device tab. First try AutoConfigure. If successful the accessories will appear in the pictorial representation of the machine. If unsuccessful, manually select the appropriate check boxes for the accessories, then Apply, and OK. =^..^=
