Kyocera Taskalfa 4500i Error Code C7460
  • bronco31
    • Aug 2009
    • 174
    #16
    Re: Kyocera Taskalfa 4500i Error Code C7460
    poor fella.. id be just as clueless if i was expected to speak and function in Swahili
    • KyoServiceManager
      • Oct 2017
      • 30
      #17
      I have attached the section of the service manual that shows the developer locking mechanism in case there was continued confusion on the location of the DV Shutter.
      "If a cluttered desk is a sign of a cluttered mind, of what, then, is an empty desk a sign?" -Einstein
      • ALi-Ali
        • Jan 2021
        • 7
        #18
        This error points to the developer shutter sensor DEVSS. It's a photosensor, and probably has toner in it.
        This is how you remove the hopper:
        [ATTACH=CONFIG]48006[/ATTACH]
        Here is the location of the sensor. You can clean it with canned air or a toothbrush.:
        [ATTACH=CONFIG]48005[/ATTACH]
        Remind me again: Why am I reading the manual to you? You can read, correct? =^..^=
        hey i clean the hopper unit now i got a new error that is "C3300", please tell me what is this error and how to i fix it?.Thanks
        i am waiting your response tell me about this as soon as possible.
          • 16425
          #19
          3300 Optical system (AGC) error
          One of the gains is FF or 00
          during the CCD lamp AGC is
          being processed.
          LED lamp PWB
          1. To check the lamp, execute U061 CCD
          (see page 1-3-149).
          2. Confirm that the wiring connector is
          firmly connected and, if necessary,
          connect the connector all the way in.
          LED lamp PWB and ISC PWB (YC6)
          CCD PWB (YC2) and ISC PWB (YC9)
          ISC PWB (YC3) and Main PWB (YC11)
          3. If the wiring is disconnected, shorted or
          grounded, replace the wiring.
          4. If the LED lamp won’t light, replace the
          LED PWB and execut U411 (see page
          1-3-149).
          CCD PWB Replace the ISU and execute U411 (see
          page 1-3-149).
          ISC PWB Replace the ISC PWB and execute U411
          (see page 1-3-149).
          Main PWB Replace the main PWB (see page 1-5-58).
          • ALi-Ali
            • Jan 2021
            • 7
            #20
            Hey please share the book that you mention and also guide me step by step how to fix it.
            Thanks.
              • 16425
              #21
              Thanks.
              Sorry, but there's no way I can give you step by step instructions on how to repair because I'm not in front of the machine. You're gonna have to troubeshoot the problem and in order to do that you really need a service manual.
              You can probably get a manual here:
              We can supply the latest Printer firmware & Photocopier firmware. Click Here For - Ricoh, Konica Minolta, Kyocera, Lexmark or Canon Firmware -
              Or you can always donate to the site and ask for one here:
              https://www.copytechnet.com/forums/s...nual-requests/
              • Crusher
                • Jan 2018
                • 17
                #22
                Open from the cover. See a lock and unlock symbol. It needs to be in locked position.
