Fax system m and km 5050 or km 3060
  • n25an
    • Jul 2008
    • 1030
    [Misc] Fax system m and km 5050 or km 3060
    I have an issue... two actually... one.... no matter what I do... the fax system m will not give me a fax recieved log... either on the display or otherwise... and two... no matter what I do I cannot get the fax system m card to fax forward anything but tiff files... has anyone faced this issue before also... to squash a bug... latest firmware on both machines... and both machines flashed with fax card installed... I am completely lost... update... the km 3060 now gets logs of received faxes but it does not record the numbers... in otherwords... dates and times but no phone numbers... any ideas would be appreciated...
    Sad To Say I Don't Have a Life
    I do this stuff on the weekends too
    • 22999
    Re: Fax system m and km 5050 or km 3060
    The trick that I've heard is to remove the fax card, load firmware, re-install fax card, re-load firmware a second time. It applies equally to FalconIII and Stratos.
    Were you aware of a firmware bug affecting fax receptions on FalconIII, versions 2.41, 2.43, & 2.44? I believe that current firmware is v 2.45a.
    I have seen a few failed fax sys (M) cards. I hope that's not the case. Replacements seem to be hard to get. You cannot use a fax sys (M)2 in the FalconIII, but it will work in the Stratos. =^..^=
    • n25an
      • Jul 2008
      • 1030
      why does kyocera still sell copiers... man this is like windows... aaaaahhhhhhhh..... sorry.... just had to get that out.... ok... no I was never aware of a firmware bug regarding fax reception... ok... I will try the firmware update... without fax card then firmware update with fax card... I will get back to you on this in about an hour...
      • n25an
        • Jul 2008
        • 1030
        OK... tried updating firmware on km 3060... now the fax reception logs have entries but they are blank... no phone numbers... any suggestions... and does anyone have a link to older firmware for km 3060 and km 4050???
        • n25an
          • Jul 2008
          • 1030
          ok... per kyocera... the fax on the other end has to have the name and phone number programmed in... then the receive log will pull that information... if not then the fax receive log will either record a blank line or nothing at all...
          • n25an
            • Jul 2008
            • 1030
            now concerning the fax forward saving only as tiff... contacted kyocera on that note and they said change the setting in the web interface.... under fax tab... under advanced... under forward... change file type to pdf... then reboot... this should change it... if not then reload the firmware...
            so I guess I am back to firmware... for tiff issue... well atleast I got an answer on the fax receive log...
