CS500CI remove jammed paper in the connecting slot
  • cbs
    • Apr 2011
    • 86
    Getting the above message. Don't know what the "connecting slot" is... anyone seen this?
  • copymech
    • Sep 2011
    • 196
    Re: CS500CI remove jammed paper in the connecting slot
    Ive looked in the ops manual, srv manual and I cant find any reference to the message. Im curious what you found at location.
    • cbs
      • Apr 2011
      • 86
      Okay, the jam was at the Transfer Belt/Transfer Roller (J31). The cause.... the Transfer Belt had ripped on the underneath leaving a 6 inch hanging thread of rubber. As the Transfer Belt rotated the hanging thread caught in the cleaning section and bound the Transfer Belt to the point of no movement.
        • 23009
        It's a common failure. That ribbon of rubber is intended to act as a guide to keep the transfer belt on track with the pulleys, but occasionally it will peel off, get tangled, then stop the belt from turning altogether. The paper stops right at the primary transfer belt since it's not turning. There does not seem to be any correlation between copy count and the failure. =^..^=
