Taskalf 520i C8040 error keeps happening!
  • Techman1000
    • Dec 2010
    • 44
    I reset the finisher error 906 2 or 3 days later they call back with the same thing, i've took the finisher apart can't find any problems.
    When I run test copies stapling & finishing everything works fine.
    Anybody have any clues?
    Model Taskalf 520i
  • Tonerkiller
    • Oct 2012
    • 667
    Re: Taskalf 520i C8040 error keeps happening!
    Adjust the finisher interlock. While the machine is running the switch can break contact if it is just making it.
    • vmchong
      • 22
      I had a same problem! I try every step with no help. Did you able to fix it?
      • blackandwhite
        • Aug 2012
        • 67
        check the photo interupter located in the finisher tray rail ...change the upper one ...i had the same problem....atlast i got this and changed it...machine is working fine...
        • eddie110171
          • May 2012
          • 133
          I had a similar problem it ended up being the guide rail was somehow out of place and the carriage was occasionally, like once a week catching as it passed the middle section. I didn't take it apart just tweeked it and it has been fine for over a year.
          • ss12
            • 289
            Try this link http://www.copytechnet.com/forums/sh...ad.php?t=70940
            • mmateev
              Anyone else have new info on this issue. I have this problem and can't fix it still. So far replaced : 305JA71490,305JA70070,305JA70490,305JA71480, Also, belt assembly as well(305JA73180). No luck so far. Maybe, I should go with finisher main board? Any other ideas. Thank you
