Kyocera FS-c2126MFP+ Varying Color Registration
  • alpha-omega tech
    • 80
    We have a new Kyocera FS-C2126MFP+(one month old) with a total of 4500 on it. The color is 1100 and black and white is 3500. The color registration has to be adjusted at least every three days or the prints and copies will look like a 3D image. We have the latest firmware, and we did the registration firmware. We also put in a new transfer belt per the Kyocera Hot Line. We also did the firmware again and the registration firmware. The power is good. We have the same model at the locacation now as a loaner and there are no issues. Has anyone had this issue before and a resolution. Thanks for your help in advance.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Kyocera FS-c2126MFP+ Varying Color Registration
    Paul@justmanuals.com
    • Tonerkiller
      • Oct 2012
      • 668
      It says to do the color calibration then the color reg. or the reg will not take properly
      • woozone
        Hello,
        got exactly the same issue on our FS-C2126MFP+, was this ever solved?
        help would be greatly appreciated
        • Kidaver
          Ghoulscout
          • Apr 2011
          • 912
          take out your transfer belt and open and close the lid slowly to make sure your IDC sensor shutter is sliding open. If it's not your registration gets further and further out of alignment each time it tries to calibrate.
          "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
          • copymech
            • Sep 2011
            • 196
            There are new tech pubs out today for this problem. KDAconnect.
            • Kidaver
              Ghoulscout
              • Apr 2011
              • 912
              just saw them myself which is good as I have a machine doing this sitting here in the shop I don't really want to work on....I hate these machines...
              • 10871087
                • Jan 2005
                • 1062
                Who doesn't?
                Also, check out the following link, it won't help you fix a shit-box copier but it will explain the pain: A Doctor Explains Why Getting Kicked in the Balls Hurts So Damn Much | Nerve.com
                • Rissa
                  I am having a similar issue, but with a Kyocera 205c. I have tried recalibrating it. B&W is alright by itself. Just have a problem in auto and full color. Any suggestions?
                  • Kidaver
                    Ghoulscout
                    • Apr 2011
                    • 912
                    205c is an entirely different beast...if you've done your color calibration and color registration and still have issues I'd try a different transfer belt to start with.
                    • Rissa
                      U468 ended up fixing the issue, but if it happens again i will try the transfer belt. Thank you.
                      • woozone
                        is there any way to access the KDAconnect documents as end-customer? "public" account seems not to work.
                        • Tonerkiller
                          • Oct 2012
                          • 668
                          No
                          • MFPTech
                            • 486
                            There is a special firmware for this on kyocera site.
                            • woozone
                              our FS-c2126MFP+ still has this issue. If someone has access to the latest firmware, i'd be thankful if you could provide it.
                              I assume this is the shutter you are referring to, this seems to work: http://i.imgur.com/Lg30Ifg.gif
