Kyocera KM5035 fax problems
  • brewster67
    • Jul 2011
    • 167
    I am having a problem with fax on a KM5035. The machine will send but not receive. When calling the machine it just continues to ring and never pick up. Had phone line checked and it was ok. Hooked up a different fax and it works just fine. Did resets U600, U601, U602 and reset all data. Machine still does not receive Replaced the NCU and Fax control boards, still will not receive. I am out of ideas and just looking to see if anyone has any ideas on what to try next.
    • 23009
    Re: Kyocera KM5035 fax problems
    Could the line be plugged into the handset port (symbol shaped like a phone) instead of the line port (symbol shape RJ11 jack)? =^..^=
    • brewster67
      • Jul 2011
      • 167
      I double checked that the line was plugged into the correct port. I even tried the other port just to be sure and then I lost dial tone and could not send.
      • darry1322
        • Oct 2010
        • 817
        Make sure you are using a two-wire phone cord instead of a four-wire cord.
        • Geo
          • 662
          Try replacing the flat ribbon connector, it has given me strange problems in the past. Also make sure they are not piggy backing a DSL on the fax line.
          Good luck.
          • brewster67
            • Jul 2011
            • 167
            Thanks for the input, I will check these out next week.
            • nmfaxman
              • 1702
              Is it sent for manual RX in the user settings?
              Just a thought.
              My signature says it all.
              • brewster67
                • Jul 2011
                • 167
                I did check that it was set for auto RX. I tried setting it to manual RX and called it with my cell. It never rang in at the machine. I took the same phone line and plugged it into a stand alone fax and called it and it went thru and the fax picked up. I have them using the stand alone fax until I can figure out why the KM5035 will not receive. Thanks for the ideas I'm at the point of trying anything.
                  • 23009
                  Good luck.
                  The ribbon cable is a good idea. I've had some seriously strange symptoms from a damaged ribbon cable.
                  For example:
                  Can't access service mode. Can't download fax firmware. Can't access Fax Defaults in the System Menu (only the double beep). Can't access Fax Reports tab in the Fax screen (button grayed out). "Cover Open" indication when no covers are open. "Please Wait. Cannot be combined." when attempting to fax out.
