KM-4050 can not enter service mode - C code error on panel
  • mcfip
    [Error Code] KM-4050 can not enter service mode - C code error on panel
    I have a KM-4050. C-Code = 0640 (HDD failure).
    Trying to enter Service mode to format the drive viai U024 - Drive Format function.
    The problem is, the C-code never goes away. I never see the Maintenance Mode Entered message.
    W/ the C-Code error on the display panel, I press the STATUS button and enter ######## (the 8 digit SM code) At this point, the display should change to: Maintenance Modem Entered, but it does not.
    Any ideas what I am missing? Do I need to do something special before I can enter Maintenance Mode?
    This thread: http://www.copytechnet.com/forums/ky...vice-mode.html comments:
    Unless you have a C-code then you can go in usually with XXXXXXXX
    as if something extra is required when a C-Code is displayed.
    Another thread on another site comments: If you have a C code, you may need to open the front door
    Thanks,
    Mike
  • JR2ALTA
    • Feb 2010
    • 2030
    Re: KM-4050 can not enter service mode - C code error on panel
    Thanks,
    Mike
    You might not get in. You can try with door open.
    I would try a CF firmware upgrade, not USB and let it boot from that.
      • 22999
      Reformat is not always the answer. Maybe you might consider replacing a failed hard drive? Once replaced, you'll want to reload firmware. =^..^=
