FS-C2626MFP Updates
    • 23009
    FS-C2626MFP Updates
    I just noticed recently that there are three pertinent bulletins, I'd like to execute on a FS-C2626MFP.
    The first is C4600 errors, in which the laser slit glass cleaner stalls. I don't think that I'm going to be replacing laser assemblies for a $0.10 piece of molded plastic. I think I'll try to lubricate for this problem. The bulletin explains this one pretty well.
    The second is Door Open indications, especially after opening the top lid. The bulletin explains that after a certain serial number there is a change in the lever that operates the cover switch, and that the lever is not available separately as a maintenance part. How helpful! So we should just throw out any machines before that serial number? I don't see the customer liking that too much.
    The third is light images issue, in which the bias contact spring makes poor contact. Again, the bulletin identifies a problem and serial number range, but offers no solution. Don't you just love Kyocera?
    I've started an email conversation with my tech rep ... at least I think he's my tech rep. I get the feeling that I am irritating him with silly questions. He never really answers my questions. I don't know why I bother to ask him.
    Has anyone addressed these updates? Do you have any updated part numbers? Any help will be appreciated. =^..^=
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    Re: FS-C2626MFP Updates
    Our tech rep here has been really good. If we have any of those problems Kyocera have been sending us out a refurbed unit with all the mods for permanent replacement. We simply box the old one into the replacement packaging and send it back, they repair and the cycle repeats.
    Having said that we did do the door switch lever a few times before. I think it took about 5 or 6 hours the first time.
    Just realized I'm referring to an fs-c2126, same story i think anyway.
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
    • ss12
      • Jul 2008
      • 289
      Don't know if this is the same lever as fsc2626 but the modified lever for a 2126 is 302KV02521 LEVER INTERLOCK
        • 23009
        Thank you gentlemen. Off to a good start.
        I thought that interlock lever looked unpleasant. Right now I'm just happy that there is an updated part number.
        When it comes time to do these updates I think I'll bring out a loaner, then do the work in the shop. Most of the customer locations are snug.
        • Jules Winfield
          • Jul 2009
          • 821
          In response to the #2 issue, you're right about the lever mechanism being a nightmare. I use shims on the actuator to get it to work properly. By shims I mean cut up a label or sticker into little strips and apply to the actuator to give it more girth. Not the prettiest of mods, but it works.
          But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
          • cbs
            • Apr 2011
            • 86
            We just completed our first "update" to address the hinge breakage, toner cartridge cam, and HV/Bias conductivity issues. What a nightmare?! 12 man-hours to replace these parts. We're glad the fix is here and seems to address the issues. However, taking two years to acknowledge/address the issue was ridiculous.
              • 23009
              @cbs: What parts/part numbers were required to complete these? The bulletins are notably un-specific.
              • cbs
                • Apr 2011
                • 86
                1
                302kv02501
                ratchet shutter
                4
                y
                $5.48
                2
                302kv02510
                holder joint
                4
                y
                $1.00
                3
                302kv02461
                cam toner supply
                4
                y
                $5.48
                4
                302kv02521
                lever interlock
                1
                y
                $1.00
                5
                302kv02e50
                case spacer
                4
                y
                $1.00
                302kv94470
                1
                y
                $50.32
                  • 23009
                  Perfect! If only my tech rep could have done that a week ago.
                  Thanks for all the help! =^..^=
                  • cbs
                    • Apr 2011
                    • 86
                    no problem. Also, if you need the Hinges that break...
                    HINGE LID R 302KV02542
                    HINGE LID L 302KV02532
                    • xeroid
                      Document Technologies Pro
                      • 148
                      I am fighting one of these guys (c2126) that another tech spent three days with the bulletin and never did get working. I am struggling with the same issues along with several broken harnesses from the original repair. I got it back together and the switch won't actuate. modified a spacer to fix that and am waiting on a backordered ribbon cable. The refurb provided mentioned earlier sounds pretty good to me.
                        • 23009
                        Thanks xeroid. I'll be interested in your conclusions. =^..^=
                          • 23009
                          I did the updates yesterday. The first time is always the worst.
                          It was 7.5 hours to get the machine re-assembled, then another 2 hours to figure out that I had not properly seated the right inner panel. The symptom was "Toner not installed ... " message. The gray plastic cover on the outer right side cannot slide freely when the inner panel is not snapped in properly.
                          I had the great good fortune to have my phone battery die three hours into it.
                          Thanks everyone. If anyone wants the notes, I'll be typing them up shortly. =^..^=
                          • madas
                            • Aug 2008
                            • 313
                            Hi BC, one of our techs has done a few and can do in about 2.5ish hours if left to it so it does get quicker with practice.
                            only thing is you might not see one again for months.
                            good luck with any others
                            madas
                            • ss12
                              • Jul 2008
                              • 289
                              I had exactly the same nightmare.Started on Friday afternoon ,had to leave when the customer shut and finished on Monday morning.Following the step by step guide since this was the first one it took around 7.5 hours including like yourself putting panels back in the wrong order.IMO this should only be attempted onsite if you have a lot of space/time.kyocera should have some kind of return policy for such a major strip down for what is in effect a minor parts change
