DF-790 on 8000i
  • stevee104
    • Mar 2007
    • 214
    DF-790 on 8000i
    Have a df 790 that squeaks bad at the main tray exit roller after about a 100 copies and then it want shut up,select any other exit tray and no noise. Being the service manual on this puppy dosen't give much in a way of taking it a part and before i attempt to take it part has anybody had this
    noise and any parts need before i rip it apart.
  • copymech
    • Sep 2011
    • 196
    dissasembly not too bad. lube the white rollers. this is common.
      • 22999
      Re: DF-790 on 8000i
      This applies to pretty much any Kyocera finisher. Look for white rollers. Lightly lubricate. Run a bunch of paper to run off any excess oil. =^..^=
      • stevee104
        • Mar 2007
        • 214
        Re: DF-790 on 8000i
        Thanks guys i will tackle it tomorrow and see how far i will take it down,
        if their any special lube you guys use without having to tear it
        completey apart let me know.
