TA-250ci FYI
  • madas
    • Aug 2008
    • 313
    TA-250ci FYI
    Hi, Had this weird one that I have never come across before.
    After power outage the customer started having printing problems, thier IT changed some damage routers/adsl modem.
    fault was they would print 1 job then the m/c appeared off line, so done the usuall tests and I could print from laptop with no errors.
    anyway turned out that the 1st tray motor was going faulty, no codes on the error log at 1st. we tested the motor manually and could see the motor trying to turn then after a few goes it finally coded out C1010. replaced and all was working fine.
    hope this is helpful as it did not occur that this would be the problem.
    madas
    • 22932
    Re: TA-250ci FYI
    Interesting! So do you think the shorting 24vdc was somehow disabling the print or network functions? It was lucky that you got it before it took out the engine PWB.
    How exactly did you come to this conclusion without an error code? =^..^=
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      Re: TA-250ci FYI
      Have seen print jobs held up because paper was in wrong eg letter in legal tray and paper edge wasn't far enough over to hit paper switch. If you look at command centre you can see that is will say to check tray 1.
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • madas
        • Aug 2008
        • 313
        Re: TA-250ci FYI
        one of our techs had heard of this once in our Austrailian office and although I didnt check for this sort of fault I did the network checks and 1st thing printed the error log which showed nothing at all to point to this. the customer had not mentioned any problem with the tray and it was thier default tray.
        pesonally I think the motor was causing a draw on the supply and caused the problem.
        just thought this might save someone some time.
        madas
        • madas
          • Aug 2008
          • 313
          Re: TA-250ci FYI
          Hi, the only way this one would print was to either reboot the m/c or unplug then re-connect the n/w cable.
          print job did not make it to the printer after 1st job sent. this all led to us thinking there was something on the n/w causing the issue.
          We found after that in command centre it showed error status but no indication as to what was the error.
          now saying that, I could print multiple jobs from my laptop and also we have TA-500ci in our workshop which has a tray 1 fault but that does not fail to print.
          madas
          • Kidaver
            Ghoulscout
            • Apr 2011
            • 912
            Re: TA-250ci FYI
            Usually when you have these paper lift motors the machine won't code out right away. As it says in the manual "After cassette 1 is inserted, lift switch 1
            does not turn on within 12 s. This error is
            detected four times successively." Several machines I've troubleshot, which annoys me as I have to 906 it and wait, is that it will try a few times and not error out until it fails several times. My guess is it might be something to avoid the machine coding out due to maybe paper getting caught behind it so that it can be removed and a problem fixed before coding out. But that would require a customer actually looking to see if paper is behind the tray. Great idea in theory, but in reality we know a customer would never search for paper behind a tray and just wait to call in a service call once the machine does code out.
            "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
            • darry1322
              • Oct 2010
              • 817
              Re: TA-250ci FYI
              I've seen several of these machines (300Ci, 420i etc ) go offline due to a tray error. It only shows up on the panel if you try to manually select the tray. Otherwise if you have similar paper in another tray, copies work fine. If you pull up Command Center nit will display the error message in the status window.
              • Tonerkiller
                • Oct 2012
                • 665
                Re: TA-250ci FYI
                madas
                We had the same excact issue. The way I figured it out was by looking at the web page and there it showed that tray one was disabled.
                • madas
                  • Aug 2008
                  • 313
                  Re: TA-250ci FYI
                  No paper behind trays to stop the lift, I think where I put my laptop on it used one of thier other trays and thiers was defaulted to tray 1. Yeah Found out that the tray was not working once I had heard of this and asked thier IT guy to just check the tray.
                  Added this to my list of basic checks for this sort of issue,
                  I just never had a tray motor cause this fault before but have learned a lesson now.
                  madas
