Is there a Kyocera that can do high volumes of label printing if not then which brand
  • yourownfree
    • Dec 2007
    • 474
    I have a grocery store chain that does high volumes of label printing. By high volume I mean about 400 labels at one time non stop, each store, all at once. I cant find a printer that will do the job. I need a new style printer. What is working is an HPp3005. In the past Lexmark t650 worked with a few problems. Here is the big problem. Oh and even tried a ML-5512 Samsung monster. Now the problem. they want speed. They want to run out of specs and by that I mean they dont want to have to select labels they want to run in plain paper mode so it goes faster. I know you dont have to tell me what you are thinking about that one. The monster Samsung ML-5512ND runs at 55 ppm unless you say labels now its down to 8 ppm. thick about 35 ppm but then it begins to hang up at the fuser. I need to sell them about 20-25 printers but I only have Kyocera,Samsung and maybe Brother, and maybe Canon, but cost to operate plays into this as well.
    These labels need to be run in as short as time as possible as these are the price stickers that need to be placed on products by daylight. The printing starts at midnight. Do have an account running labels in a high volume fashion do tell what is working because I am out of ideas. As you can see I need a printer that will print labels in plain paper mode maybe with a fuser adjustment if it comes with one. Yes I know it doesnt make sense, but a sale does make sense. What they have now are Lexmarks and Hp's. t-650's and HP p3005. They have even used hp 2200 printers in the past but even they are too slow. But 22 ppm is still better than 8 ppm for the monster Samsung ML-5512ND. I am also told by our sales rep that there is a new toner law where the toner has been changed due to health concerns. They arte saying maybe the new formula does not adhere very well. Matter of fact an engineer at Samsung stated that.
    Here is my Question: What printer can I use that will produce at least 33 or ppm using labels without jamming or problems?
  • Venom
    Technical/IT Support
    • Nov 2009
    • 765
    Re: Is there a Kyocera that can do high volumes of label printing if not then which b
    I wouldn't put a high speed printer/copier in to do labels, they have higher temperature fusers and heat effects labels so you are going to run into issues. Maybe Riso?
    IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • 23009
      Yeah I would never want to service this label printer, ever. Especially running out of specs, and fusing poorly. My recommendation is Don't sell a Kyocera or Konica Minolta. In that way, I'll probably not have to look at it. Regardless, the labels must feed letter-R. Labels are not made to be fed letter, and it will become you're second home, peeling labels off of everything.
      You and your customer are going to be very unhappy together. =^..^=
      • Jules Winfield
        • Jul 2009
        • 821
        I would look into maybe the highest speed inkjet type printer you can find. Anything with a fuser is going to be a nightmare for everyone involved.
        But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
        • nmfaxman
          • 1702
          Sell them a 100CPM machine so that when they do labels, it will do it @ 75CPM.
          Ignorant bean counting manager expecting the most while paying the least.
          I would walk away because it could turn into a nightmare.
          • 20gaugeO/U
            • 557
            Riso will peel the labels off when it buckles in the second paper feed area.
            • DWise
              • 895
              Let us know when you find a printer that doesn't jam
              Do for one what you wished you could do for everyone. - Andy Stanley
              • bilyahn
                • Dec 2006
                • 1470
                Why don't they just print them earlier. It's not like they don't know what the prices are going to be??????????
                • HP:guy
                  • Feb 2013
                  • 279
                  Look at Zebra and Data Max printers They are label only and very reliable.
                  Using multiple printers they can spread out the job.
                  • Barış KURT
                    • Jul 2010
                    • 72
                    may be CANON LBP-6670DN or HP LaserJet P3015DN Mono Laser
                    my customer use hp 4250, they are glad.they have printed 10 - 12000 pages A4 label per monthly.
                    we have set "fuser mode 2" on hp 4250.
                    Black is Kyocera , Color is Gestetner.
