TaskAlfa 5500i Image failure after service
  • lanierboy
    • 149
    Good Morning,
    I have the below problem on a 5500i after a service. the original fault was a charge roller fine line so as the machine was near a service we fitted the complete kit, I have since changed another kit (i case we had a duff one ) but the problem remains even with the original units in, we have followed exactly the procedures and done the machine resets, we have also fitted a new HV board but the problem remains. has anyone seen this before? solution??
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5015
    Re: TaskAlfa 5500i Image failure after service
    Corrupted bias on drum or developer.Check connections between machine and this two units.Transfer roller connection can be bad also.
    • Techman1000
      • Dec 2010
      • 44
      there's a rubber piece right in between mag roller and housing that's hard to notice (see attached pic)
      • Jamil Mungur
        • Feb 2013
        • 34
        Hello
        serviced a Taskalfa 5500I and getting exact same problem.
        Checked :
        1. No rubber found between mag roller and housing
        2. Connectors seem ok.
        Please help
        • blackandwhite
          • Aug 2012
          • 67
          hai.... Try to do AC caibration from U464,may be it will help you,best of luck...........
          • Venom
            Technical/IT Support
            • Nov 2009
            • 765
            This looks like main charge is being lost....possibly dev bias.... but it won't be drum ground or transfer loss
            IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
            • Tonerkiller
              • Oct 2012
              • 668
              Make sure that the dev unit is going up and smoothly into place.
              • Jamil Mungur
                • Feb 2013
                • 34
                Hello
                thanks for all the replies.
                Did AC CALIBRATION : Problem not solved
                Venom : how can i confirm if its a main charge loss problem ?
                Tonerkiller : yes the developer unit gets into place smoothly.
                I am out of resource here friends. Please help
                • blackandwhite
                  • Aug 2012
                  • 67
                  Originally posted by Jamil Mungur
                  Hello
                  good... still same problem.... remove all the drums,dev-units.transfer belt etc....including back and side covers.... blow with air gun....may be some were toner or foriegn particles cause the arcing... remove and reinsert the hvt ,engine main pcb connectors....check for any damaged wires....hope it will solve ur problem....
                  • Jamil Mungur
                    • Feb 2013
                    • 34
                    Hello
                    thanks for reply blackandwhite.
                    I worked on the machine today.
                    Removed the developing unit, drum, and transfer belt. Removed power supply and the hvt.
                    Blowed air on the power supply and hvt and also at the back of the machine. Used vacuum cleaner to clean the drum and developer area in the machine. Cleaned the laser.
                    Removed the developer drive motor and cleaned the contacts behind the motor.
                    I must admit that i did not dissasemble the engine and main pcb. But blowed air on thrm and did visual check all seem ok also checked all connector that were accesible.
                    None of the above solved the problem.
                    I am starting to suspect the hvt pcb. I wish to be sure the hvt is faulty and was looking gor a way to test to be sure before ordering it. I looked in the service manual but cannot find it.
                    Any further tests or any clue to solve this problem i will be greatful.
                    Thanks for support.
                    • blackandwhite
                      • Aug 2012
                      • 67
                      Hello
                      Thanks for support.
                      well...try with your own ideas.....now these machines are not having a proper fault find guidelines... we have todo our own methods...every one is waiting for the result,which you are going to brought ....may be some un noticed chilly issue will be there... keep try....best of luck.....
                      • Jamil Mungur
                        • Feb 2013
                        • 34
                        Ok thank you very much. I will keep on trying and keep this thread updated until i find the solution.
                        • Jamil Mungur
                          • Feb 2013
                          • 34
                          Got update from olivetti technical support. He told me to wash the transfer roller in the developer unit with soaped water. Quality got better but not completely solved.
                          • jmaister
                            certified scrub
                            • Aug 2010
                            • 755
                            I dont think its the developer, they dont produce streaks.
                            the base layer is fine, looks like primary transfer is mucked up. Taskalfa Saturns when it was introduced, when the drums are weaken to a point that it starts to leak charge, the drum will "dry rub" the transferbelt. The streaks look like this. But this looks worse.
                            and 464 is not where you do calibration, its u140. does 5500i have one?
                            Idling colour developers are not healthy developers.
                            • Jamil Mungur
                              • Feb 2013
                              • 34
                              Hello jmaister. Thank you for reply
                              Did U140 previously but did not solve the problem. Do you think the problem is with the drum ? The problem is that i already replaced the drum.
                              Any support will be highly appreciated.
