TaskAlfa 5500i Image failure after service
  • jmaister
    certified scrub
    • Aug 2010
    • 755
    #16
    Re: TaskAlfa 5500i Image failure after service
    Originally posted by Jamil Mungur
    Hello jmaister. Thank you for reply
    Did U140 previously but did not solve the problem. Do you think the problem is with the drum ? The problem is that i already replaced the drum.
    Any support will be highly appreciated.
    do you have another full right side unit available to swap with, cuz the transfer belt is on there.
    did you hit anything during service? was this unit pulled out first?
    Idling colour developers are not healthy developers.
    • Jamil Mungur
      • Feb 2013
      • 34
      #17
      Hello
      i tried to look for a full right side assembly but could not find. Please note that the transfer belt is new.
      The machine is still faulty as client is starting go get angry at us.
      I asked the engineer who did the maintenance he said he took care ( of course he will say that ) but i check the right side assy it seems to be ok and closes smoothly.
      I am out of solution guys. Please anyone got this problem ? Support will be much appreciated.
      • habik
        • 2013
        #18
        Pull the drum out and check if the coupling has the Orange tape still in place, which is sometimes not noticed when installing new kit.
        Whilst you have the Drum out give the laser window a good wipe with micro fibre cloth! paper dust remover re-attach it.
        Is the IDS sensor behind transfer belt clean? It is under cover but I would still check that.
        Then the transfer belt it self is it plugged in?
        Reg roller dust remover..is it clean
        Have you vacuumed out the Dev Duct system from the back and changed the filters ALL of them top, side and inside?
        Can't think of anything else right this moment.
        Good luck.. let us know!
        Firmwares HERE
        • jmaister
          certified scrub
          • Aug 2010
          • 755
          #19
          oh dear, best luck to you sir.
          maybe time to call factory?
          • Jamil Mungur
            • Feb 2013
            • 34
            #20
            Dear all
            thank you for your support. I tried all the proposed solutions but non worked. I ordered a new maintenance kit and will do the maintenance once again.
            Can anyone tell me how we can check the high voltage pcb ?
            I worked on OCE TDS SERIES machines and i used to check the voltages on the test points on the high voltage pcb.
            • Barış KURT
              • Jul 2010
              • 68
              #21
              I think "main charge error" on former machine (2530 3530 etc.)Replace charge corona (may be charge roller unit at 5500i) or drum unit.
              Black is Kyocera , Color is Gestetner.
              • Hose1cook
                Defective Technician
                • Jun 2008
                • 80
                #22
                I had this exact problem on a 5501 last month, the machine was 3 months old with 98K on it and the streaks were on the machine rear side of the copy, they got progressively worse in a copy run. First thing I did was change the drum and then the transfer belt with no change. After talking to the hotline and getting a bunch of useless help I tried a new DV unit, still no change. As a last resort I did another AC Calibration and it has been working ever since. I had previously done AC Cal with no success and I don't know why the combination of the new DV Unit and AC Cal worked but it did. I know you said this machine had a new Maintenance Kit but maybe the new kit had a defective DV Unit in it? Good Luck.
                • Jamil Mungur
                  • Feb 2013
                  • 34
                  #23
                  Dear all
                  Thank you very much for you interest in this thread. I finally received the maintenance kit + a High voltage pcb.
                  Replaced the kit, that is drum, developer and transfer belt and followed all the instructions ( including AC calib ). The problem changed but was not solved.I attached IMG 1 a photo of the output i am getting.
                  There is also something strange, if i do 1 print i get output IMG 1 but if i do more then 1 print the output changes and its as IMG 2.
                  I tried to replace the high voltage pcb but it had no effect on the prints.So i put back the old high voltage pcb and carried out some more troubleshooting.
                  I tried to swap the old drum and developing units to see the result :
                  Old drum + new developing unit = problem same as the actual attached document
                  New drum + old developing unit = back to problem i got at first, that is whole document covered with lines.
                  From this i can conclude that the origin of the problem is somehow with the developing unit. So to my opinion i should now consider changing the Engine PCB.
                  Please give me your opinions.
                  • habik
                    • 2013
                    #24
                    Dear all
                    I know that this will sound silly, but can you give the optics and the white calibration strip a proper clean! Then the lens and later CCD. Plus whilst at it check the scanner connections!
                    Sent from my iDon't believe in marketing device using Tapatalk
                    Firmwares HERE
                    • Geo
                      • 662
                      #25
                      Is it possible that somehow the lift assembly for the DV unit is damaged,twisted or misaligned to the drum unit. From your pic it looks as if the charge roller and or the DV unit is not making proper contact with the drum.
                      Just a thought...
                      • meestir
                        #26
                        Possible contaminated toner reserve?
                        • habik
                          • 2013
                          #27
                          That seems like a possibility to me
                          Is it OEM toner and has it been stored properly ?>
                          Firmwares HERE
                          • Jamil Mungur
                            • Feb 2013
                            • 34
                            #28
                            Dear all
                            I received the Engine pcb today and tested it. It seem luck is not supporting for this machine; I replaced the engine pcb and of course i shifted the eprom form the old engine pcb to the new engine pcb as stated in the service manual.It gives me error F040 which indicated a communication problem between the engine and the main pcb, i verified the flat cable that links the main and engine pcb and its well seated.
                            If i put back the old engine pcb there is no error code :-(
                            The machine is always on original toner and our toner are stocked in appropriate conditions. As for the developer contact of drum to developer i checked and cannot see any misalignment.
                            I will keep you all updated, open for all opinions.
                            • jmaister
                              certified scrub
                              • Aug 2010
                              • 755
                              #29
                              first page looks like the drum charge is leaking. What's making it leak is my question.
                              Also, if you take a look at the km3035 service manual for timing charts(assuming the principle is the same), the main charge stays on the duration of the operation(2 of 11x17), so drum always have charge on it(beside charge erase).
                              what's shorting it?? or dissipating the charge...?
                              AND, the black area is uneven, bottom heavy. looks physical but idk...
                              • kmaman
                                • Feb 2012
                                • 9
                                #30
                                We had something similar to this. our first copy out of memory was always good but it got worse after that and after about 5 pages we had examples like yours. We changed drum and main charge. Neither helped the situation. We put whiteout on the hv plate on the back of the main charge to make sure the spring in the back of the machine was making good contact with the main charge roller. It wasn't making that good of contact so we carefully stretched it...we also cleaned off the very tip of the drum drum grounding rod. Our issue went away immediately and hasn't come back.
