I have had a couple of machines that produce a totally black image at times. some times only at the front and rear of image. I remove the charge corona and of coarse there will be no image, but could this be the charge corona arcing?
Black Image
Re: Black Image
Yes, it's probably primary charge loss. Could be arcing, could be a failing HVT. The arcing is more common. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^=Comment
