Kyocera KM3060 cassette heater / dehumidifier
  • Rolandito
    • Aug 2007
    • 91
    Hi.
    Anyone knows how to turn on the cassette heater.. or set on
    I am having transfer problems caused by humidity on paper.
  • kyrenecopy
    • Apr 2012
    • 205
    Re: Kyocera KM3060 cassette heater / dehumidifier
    drum heater U339
    0=off
    1-4=on when in standby
    Testing 1-2-3, testing, testing. Is this thing on?
    • Zackuth
      • Aug 2009
      • 448
      Isn't there a jumper wire that needs to be connected also? Or was that on the 4050-5050 models.
      If at first you don't succeed, redefine success
      • kyrenecopy
        • Apr 2012
        • 205
        the info came right out of the book, didn't see anything about a jumper?
          • 23009
          Casette heaters are usually described in the Installation Guide. That's where I'd look. =^..^=
          • omendes
            • Jun 2011
            • 11
            There is a small cover on the back panel. You will find a connector that needs to be plugged in.
            Heater will then come on.
