CS 3040 C 6000
  • kmtech
    • Sep 2008
    • 125
    CS 3040 C 6000
    Hi All, I have a 6000 code on this machine, the main thermistor looked rough so i replaced both, lamp good, fuses good. Reset after putting it back in and now the touch screen wont respond, so no reset. I updated the firmware and it started to work and i reset the code, but the code came right back and the touch went out again. so i brought it in and was woundering if i could get some help....
    Thanks in advance.
    Bill
  • JustManuals
    • Jan 2006
    • 9919
    Re: CS 3040 C 6000
    Paul@justmanuals.com
      • 22861
      Re: CS 3040 C 6000
      How did you reset the error? Fuser errors are unique in that you can only reset them in sim U163. =^..^=
      • kmtech
        • Sep 2008
        • 125
        Re: CS 3040 C 6000
        I have manuals,
        • kmtech
          • Sep 2008
          • 125
          Re: CS 3040 C 6000
          I cant reset due to the fact the op panel dont respond.
          • thekeg19
            • Jul 2008
            • 29
            Re: CS 3040 C 6000
            There is a bulletin regarding the tablet, could just be a coincidence that it went out at same time. SB-8645
            • kmtech
              • Sep 2008
              • 125
              Re: CS 3040 C 6000
              Thanks, thekeg, i will check it out on the km.
              Bill
              • kmtech
                • Sep 2008
                • 125
                Re: CS 3040 C 6000
                i checked the km site no bullitin.
                • thekeg19
                  • Jul 2008
                  • 29
                  Re: CS 3040 C 6000
                  At the KDA page, tech resourses/ knowlege base/ QA/ type 8645. I would have emailed but it would not attach the file.
                  • kkendric
                    • 301
                    Re: CS 3040 C 6000
                    Order Part number 302FB25191 Tablet Operation (Touch Screen) $54.80 From Kyocera and be done with it. Common problem with many units over the past years.
                    • kmtech
                      • Sep 2008
                      • 125
                      Re: CS 3040 C 6000
                      I went back to kma and found it, thanks to your help.
                      I may just order the touch screen like kkendric said,
                      Thanks a great deal to both and all that helped.
                      Bill
