km 4050 lcd operation not working
  • quitech
    • 82
    Dear friends i have problem on lcd operation panel for km 4050 not responding if you are operating it, i try to initialize it with u201 but it continue flashing try again try again, pls friends i need you advise, what can i do? I WILL BE GLAD IF ANY OF YOU CAN SEND THE FIRMWARE FOR ME B/COS I DON'T HAVE.GOD BLESS YOU FOR HELPING ME. My email is okwudiliugoh@gmail.com
    • 23009
    Re: km 4050 lcd operation not working
    It's not firmware that you need for the display problem. You need a tablet and sponges: See this thread:
    http://www.copytechnet.com/forums/ra...tml#post311379
    302GR45040 Tablet
    302GR05310 Sponge LCD A
    2BJ25280 Sponge LCD B
    Sorry, I don't give away manuals and firmware. Don't ask. Those things can be purchased at www.justmanuals.com
    • Tebow83
      • May 2009
      • 92
      Most likely the operations tablet.
      I've replaced a good few if these in that range.
      • kkendric
        • 301
        Black Cat is correct, but you will need two of each sponge, unless you can carefully remove and replace them on the new Tablet PCB, as Kyocera calls it.
