Kyocera FS C2126 MFP color Calbiration issue. copy quality not good
  • kibbs
    • Apr 2013
    • 94
    [CQ] Kyocera FS C2126 MFP color Calbiration issue. copy quality not good
    Dear Techician... i am just now started the photo copier carrier.. in kyocera. i am facing one big problem.. color quality is not that much good in fs c2126 mfp machine.. drum seems good also.. still color quality is not good.. Please help me for this issue...!! last year only they bought this machine..
  • JSC
    Gimp
    • Dec 2006
    • 618
    Re: Kyocera FS C2126 MFP color Calbiration issue. copy quality not good
    It looks like the cyan drum is not being cleaned correctly, try swapping the the cyan drum with the magenta to see what happens. Kyocera have released lots and lots of mods for this machine, I suggest you make sure it is on the latest firmware and carry out all relevant modifications.
    The gene pool could use a little chlorine.
    • kibbs
      • Apr 2013
      • 94
      okay tomorrow i will exchange the drum and i reply to you...
      • madas
        • Aug 2008
        • 313
        the 2nd pic also looks like you have a charge problem?
        madas
        • kibbs
          • Apr 2013
          • 94
          Hey their today i was check the all drum with the swap and also with the latest firmware upgrade..!! then also my problem looks the same.. no change..
          Mr. Madas.. i check the charger also.. but it seems okay..!! any other solution will be appreciable...
