kyocera taskalfa 250ci 9540 Error
  • kibbs
    • Apr 2013
    • 94
    [Error Code] kyocera taskalfa 250ci 9540 Error
    After I Swap the Engine board I am getting the Error message is like 9540.. I updated the firmware too.. Still the problem seems same... how to solve this issue..???
    kibbs
    • 23009
    Re: kyocera taskalfa 250ci 9540 Error
    I'm going to guess that you didn't retain the original EEPROM the holds the machines identity. Either you used the blank one that was included with the new PWB, the slot may be empty, or you used the one that came from another MFP. In either case it's a mismatch.
