CS300Ci C7101 code
  • darry1322
    • Oct 2010
    • 817
    CS300Ci C7101 code
    posted September 20, 2013 02:35 PM
    The C7101 is coming up because the black toner sensor shows 1023 in MM155. No variation at all. The color toner sensors all read in the high 400's,
    but they change a little during the MM155 run. The Black toner sensor doesn't fluctuate at all.
    So far I've replaced the black dev motor and cleaning motor, the black dev unit, the engine board and the front pwb that the devs plug into.
    I've watched the dev augers turn in MM155 while the hopper unit is off the machine, so I know the black dev is turning. Just bugs me that the black
    toner sensor doesn't seem to be reading at all.
    Any other ideas?
  • JustManuals
    • Jan 2006
    • 9838
    Re: CS300Ci C7101 code
    Paul@justmanuals.com
    • darry1322
      • Oct 2010
      • 817
      Thanks but kdaconnect keeps me stocked with manuals....
        • 23010
        The only other logical thing I don't see in your list is the main drive pack. That'll be fun for you. =^..^=
        • darry1322
          • Oct 2010
          • 817
          We've had a couple of these drive packs with problems recently.
          I ran MM155 with the toner supply section off of the machine and can see the developer unit augers running normally.
          Thing is I still get no variation on the toner sensor value while MM155 is running and the augers are turning. Can't quite figure this one out.
          • darry1322
            • Oct 2010
            • 817
            Turns out the first new black dev unit I installed was as bad as the original.
            Went back out today and tried a different new black dev and the problem cleared right up.
              • 23010
              That's really unusual. Thanks for sharing. =^..^=
