DF-710 Lock-up Issue
  • ClarkIR
    • Oct 2013
    • 74
    Hello everyone,
    long time reader, first time poster. I have a DF710 on a 5050 that has a nasty habit of not resetting tray A to its home position. it appears to happen completely at random, and with no set amount of copies triggering the event. It also does not output an error code to maybe assist in providing a reason for this occurring. It just disallows the use of Tray A, and the staple feature. The only way we can get it to go back to default is by doing a U906. Kyocera's help desk has no history in regards to problem similar to this one.
    Does anyone know a long term, or permanent solution to this particular issue? I have already done a firmware update.
    • 23008
    Re: DF-710 Lock-up Issue
    It does display an error, you just have not been there to see it. And your enduser just flips the switch Off/On to isolate the finisher, ignoring the error number.
    Print an U000 > Event Log. In the right hand column you'll see the list of error codes. It will start with a C8xxx. If you can't figure out how to enter service mode, or do not what the code means, please consult your manual. =^..^=
    • Venom
      Technical/IT Support
      • Nov 2009
      • 765
      there are 3 black fingers that come out to hold paper down on the tray, check the spring link on that solenoid to see if broken...it can cause that
      IBM, Mita, Konica Minolta, Ricoh, Kyocera, HyPAS, Canon, Oce, Samsung, HP, TEO IP PBX/Unified Communications, Comptia Network+ Comptia PDI+ Certifications
      • Tonerkiller
        • Oct 2012
        • 668
        I have also seen where those 3 fingers were not always coming out because they were sticking to the pads behind to them.
