Kyocera KM 8030
  • Lotar
    • 76
    Kyocera KM 8030
    Greetngs,
    I have a client informing they cannot log in as admin on the web interface to add/edit and delete users.
    I dont do alot of the connectivity,( enough to be dangerous you could say) mostley im doing PMs ect.. but this was thrown at me to take care of.
    from what i gathered they are able to enter IP and log on to web (print) interface and see the copier, but they say there is no place to add users or log in as an admin.
    anybody that could help me with this would be greatly appriciated.
    thank you and have a great day.
  • copymech
    • Sep 2011
    • 196
    Re: Kyocera KM 8030
    Enable compatability mode in IE. And the 8030 has a seperate ip address for the scanner. That is where the address book will be found.
      • 23008
      Re: Kyocera KM 8030
      These machines do not have a default login like newer models. You can set up an admin login, but the default is with no password. Full functionality is available right from the first webpage.
      Like copymech says, the scanner functions and addressbook are on a separate network interface, separate IP. There should be two network cables if scanning and printing are both functioning.
      If you find that some of the scan card webpages do not open or do not interact well with Firefox, you may need to upgrade the NS-30 scan card firmware to at least version 1.4.11
