Kyocera 420i counters & Job logs
  • pope
    • Oct 2013
    • 8
    [Misc] Kyocera 420i counters & Job logs
    I have a kyocera printer model - 420i.being used by approximately 50 users.
    Users scan their documents to their respective network shares.
    However,i need to create a way such that i will be able to see which users copied/printed/scanned a specific number of pages for accounting purposes only.
    How do i do this? I have tried to see where i can create user access/login codes from but havent..
    kindly guide me
    • 23009
    Re: Kyocera 420i counters & Job logs
    It's called Job Accounting, and you've got plenty of options. The simplest and most common is to assign a 4-8 digit number for each user. The next more complex is to assign a local authentication username and password. It kind-of-a PITA typing in all those characters on the dinky typewriter screen, and you'll burn through tablets. To take that one step further, you can have the machine authenticate with AD (Active Directory). It's equally inconvenient and takes longer. Users don't usually complain too much about the first choice, and generally hate the second and third choices.
    Once you've decided which option you're going to use, You'll want to load KM Net Viewer to a server or PC that remains on all the time. KM Net Viewer does a number of things. It can cumulatively combine the counts from various MFPs to give a total usage per user, breaking down to b&w/color, prints, scans, copies, and facsimilie. It can send out warnings, like "low toner", error messages, "door open", maintenance indications, etc, to multiple email destinations.
    You should get yourself a manual. It's all in there. =^..^=
    • pope
      • Oct 2013
      • 8
      Thanks bro,I have read the manually gracefully and it seems its only possible to do this from the kyocera itself and not from its web interface...is is really so?
      How can i see,edit the user codes(the 4 digit code that the users uses to login) from the web interface....is it possible actually?
      • Kidaver
        Ghoulscout
        • Apr 2011
        • 912
        You can't do it from the Command Center but you can get KM-Netviewer or KM-Net for Accounting from the Kyocera site which allows you to manage all of that.
        "In a cruel and evil world, being cynical can allow you to get some entertainment out of it."
        • copymech
          • Sep 2011
          • 196
          There is a tool called "setup tool". It allows you to create account codes , address books , user accounts and save them. Allowing you to push it to copier using the net viewer.
          • pope
            • Oct 2013
            • 8
            my problem is that i wasnt able to login in to the net viewer...all the password /usernames i tried didnt work out...admin00,etc
            pls help
              • 23009
              During installation of Viewer, there is a screen to set up a login. If your installer forgets his password, you're screwed.
              The only way to correct this is to delete KM-Net Viewer from Add/Remove Programs. Look for password flie stored: C:\Users\username\AppData or C:\ProgramData
              It's encrypted so you can't open the file, but you can delete it so that the new installation will not use the old password.
              • pope
                • Oct 2013
                • 8
                i have reinstalled again and still no prompt to set up the password....i now dont know
                  • 23009
                  The only way to correct this is to delete KM-Net Viewer from Add/Remove Programs. Look for password file stored: C:\Users\username\AppData or C:\ProgramData
                  • pope
                    • Oct 2013
                    • 8
                    I have tried your procedure of deleting and installing the same but its all the same , even when using a different computer.
                    I dont knw what could be the issue now..coz the netveviwer installs when but i cant login nor does it give me the option to setup my login details
                    I am using netviwer veersion 5.3
                    • pope
                      • Oct 2013
                      • 8
                      is there anything that i am not doing right ?
                      I installed the net viewer kyocera but despite numerous tries, i still haven't managed to login and manage/view my job logs.
                      Is there something that i am not doing correct?
                      Alternatively,is there any other software i can use with my kyocera 420i to view,manage users and see the logs..
                      pls help
                      thanks
                        • 23009
                        KM Net Admin also serves the same purpose.
                        Sorry, I don't have anything else for you to try. =^..^=
