kyocera mita KM 5050
  • antoney suresh das
    • May 2011
    • 103
    [Misc] kyocera mita KM 5050
    Hi guys,
    Have any of you guys used a OPC drum in a Kyocera KM 5050 if yes please share some data on the subject
    thanks
    • 23010
    Re: kyocera mita KM 5050
    There's a forum post on this. The organic replacements are supposed to last 120K or 1/4 the life of the ASi drum. And requires quality adjustments to compensate.
    It just sounds like a bad idea to me. =^..^=
      • May 2011
      • 103
      Thanks blackcat many of your posts/suggestions are eye openers. Considering the price of the OPC drum is nearly 1/3 the price of the maintenance kit and expected yield nearly 1/4 of the original drum i guess like you said is definitely a "bad idea".
      Thank you once again
      • Tonerkiller
        • Oct 2012
        • 668
        Non-OEM parts and supplies never work in the long run.
        • Jules Winfield
          • Jul 2009
          • 821
          Fasho...
          Not even in the short run in some cases.
          But I'm trying, Ringo. I'm trying real hard... to be the Shepherd.
